Main vent hissing when boiler is firing
Oz
Member Posts: 8
Is it normal for a main vent to hiss vigorously when the boiler cycles on? I recently had a main vent installed and, since then, I've noticed this hissing.
Pressure?
What pressure is the boiler operating at, it should be below 2 PSI. That vent is probably too small how long is the steam main and what diameter (or circumference) is the steam main?
The mains should all be pitched so any water can find its way back to the boiler return.
3PSI gauge0 -
If you can hear the air venting...
If you can hear the air venting you don't have enough vents.
If it is steam venting, you have a broken vent
PaulSince 1990, I have made steam systems quiet, comfortable, and efficient. We provide comfort while saving the planet.
NYC RETROFIT ACCELERATOR QUALIFIED SERVICE PROVIDER
A REAL GOOD PLUMBER, INC
NYC LMP: 1307
O:212-505-1837
M:917-939-05930 -
In the future
I noticed that you cut the overhead pipe and installed a tee to install that vent.
It is much easier to drill and tap the overhead.
Try it the next time.
NYC LMP: 1307
O:212-505-1837
M:917-939-05930 -
New vent
I don't know how long your pipes are, but surely you need a vent, or vents with floats to stop the water spewing out.Start with at least 1gorton 2, and watch the pressure during the steam escape phase. When the pressure is below 2 ounces, you know you have enough. Crank the pressure down, until the new vents are silent.--NBC0 -
Pressuretrol set to
Cut-out 1-1/2 psi
Differential 1/2 psi
Looks like water level in gauge glass has also decreased since new main vent was installed and the vent hisses continuously until boiler cycles off, all of which make me think vent is spewing steam, not just air. Calling steam guy who did the work tomorrow.0 -
Verifying the pressure
If the pigtail under the pressuretrol is plugged with debris, then the pressure can rise and not trip the control, so an accurate gauge, marked in ounces can verify that the pressure is matching the settings.--NBC0 -
Vent
That vent doesn't look brand new anyway. Was it just moved? It sounds like it IS failed open.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
