Domestic hot water
Nobody
Member Posts: 7
I have oil Heat , what is the most efficient way to make domestic hot water.
how much hot water do you use?
an indirect is usually the most efficient way to make hot water with a modern oil boiler. Natural gas is cheaper at this point in time. Your location makes a difference as to what the right answer is. Electric is cheap in the Northwest U.S. and parts of Canada with hydro electric. Solar works in the sunny areas very well and well if down properly in other areas too.Cost is what you spend , value is what you get.
cell # 413-841-6726
all great....
points. What is your system? What have you got? Pictures help.....0 -
Domestic hot water
I have a old oil fired boiler ,the previous owner updated much of it. it is Mono flow system. I try to heat my home with an wood burning insert. I live on long Island0
- 120 Geothermal
- 394 Solar
