WiFi Thermostat
jim_51
Member Posts: 69
Happy New Year to all.
My daughter has a Bryant Plus 90 furnace about 5 years old. She travels and I was wondering if there is a WiFi thermostat you can recommend so she can check the temp to ensure furnace is working and raise and lower it while she is away. The unit is single stage for heating and cooling. Thanks much
Wi-fi enabled thermostat
This may be one of the applications where the Nest thermostat could actually work to advantage. It seems to be wi-fi enabled, and will give feedback on temperatures across the Internet. Due to the specialized needs of some hydronic, and steam systems, it has not been popular with many here, but for forced air, it could be a good choice.
More conventional wi-fi thermostats can be found at Pex supply.com
Ecobee is one make I believe.--NBC0 -
BayWeb is my choice, but
Ck out the recent wifi thermostat thread in the controls forum too.
Happy New Years:
TimWinter Park, CO & Arvada, CO0
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 892 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
