Water pressure gauge reads zero on new gas boiler install
BrianH
Member Posts: 7
I just had a Burnham ESC 4 installed and it's running fine but the water pressure gauge is reading zero. It seems to be circulating water and is suppling heat, the LWCO light is green. Any thoughts? The contractor tells me it's the gauge and don't worry about it
Re: reading zero
If you open a bleeder at a radiator on floor above the boiler and check for water, if water present you are ok. He can put a new gauge on later. Stay warm and Happy New Year0 -
Re
Thanks, That makes me feel better, I felt the radiators and they were all warm, I'll bleed today and see what happens.0 -
guage
Make sure that the guage gets replaced. Should show approx. 12 PSI.0
- 87K THE MAIN WALL
- 58 Biomass
- 426 Carbon Monoxide Awareness
- 113 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 161 Indoor-Air Quality
- 70 Pipe Deterioration
- 994 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
