oil to gas convert for old house
Dexter12
Member Posts: 5
in Gas Heating
1860 Farmhouse with 18" stone walls in front with addition that was probably done in early 1900's that is cedar clapboard on outside,uninsulated walls. Clapboard is in good shape,no cracks or openings,pretty solid. All the windows were replaced with Anderson last year (home is in a Historic District) north of Phila Pa
Heated space is 2050 sq ft,
Attic which which is finished but has no radiators is 400 sq ft
Currently has a Peerless WBV-03 Oil Boiler (with a tankless coil in the Boiler) and a Bradford White Electric Water Heater run parallel with the boiler, house has cast iron radiators
We are going to convert to gas and I want a boiler with an indirect tank. Also would like to go high effiency ,modcon
Any suggestions would be appreciated
Is this
a steam or hot-water system?All Steamed Up, Inc.
Consulting0 -
sorry about that,
it is hot water, cast iron radiators0 -
First thing to do
is a heat-loss calculation. That will determine the boiler size needed. If a particular contractor says it's not needed, show him the door.
Once we know the heat loss, then we can talk about equipment.All Steamed Up, Inc.
Consulting0
