Samsung Quietside
Richard_102012
Member Posts: 17
Hi,
My plumber installed 3 years ago a Quietside boiler to be use with a Wirsbo hydronic radiant floor heating system and for the domestic hot water. What a nightmare...The boiler broke down at least 50 times. Now i am looking of changing the boiler and my plumber suggest Rinnai boiler instead of Viessmann( i have Viessmann for my appartments) because he says that the quality of the Viessmann boiler drops a lots since the 80's.I'm looking for a boiler <strong>trouble free</strong> and i don't know what to choose. What would be your suggestions for the best boiler. Thank you.
Richard
Richard
Viessmann
I only install Viessmann. Have had really good luck with them. Very high quality. There are also a lot of other good manufacturers out there, triangle tube, lochinvar to name a few.
The installer is usually more important than the equipment.
James0 -
Viessmann
I would put a Viessmann or Triangle Tube in my own house if gas were available0
- 167 Indoor-Air Quality
