Dry return from nowhere
Fizz
Fizz Member Posts: 555
found in crawl space, runs parallel to return to upstairs radiator which does not heat.  This return is connected to main dry return but is not connected to any other piping.  Two concerns, could this be afffecting performance of other rads, and should it be removed and main capped where it joins?  The system is a Richardson.
Fizz
