furnace firing issue
LB_481
Member Posts: 4
furnace is only firing the first 3 burners,it goes out on flame sensor saftey.any ideas on why the last burner would not fire??
Gas
Have a licensed Hvac contractor check it. could be low gas press. you could start with your gas co. alot of them dont charge to check your furnace.There was an error rendering this rich post.
thank you RJ going to check gas pressure today ill post the result.0 -
pressure
You need a minimum of 5 inches water column to inlet of most gas valves and 3.5 inches to burner on most furnaces, these setting can change if you have a 2 stage valve and on commercial burners. most diaphram style gas valves depend on this 5inch to 3.5 inch pressure drop to operate correctly.There was an error rendering this rich post.
Dirty burners
Could just be a dirty cross over on the burners.0
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 892 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
