Mod Con Boiler And Zones
GordoG
Member Posts: 15
Recent replies to a post on a new system design seemed to indicate that mod con boilers don't like or work well with heating zones. My house has a 1" pipe diameter series loop on the first floor, probably dating to 1950. The radiation fins are steel fitted over the pipe. My second floor is a separate zone with with regular baseboard from the late 1950's. There are two rooms with a baseboard in each room. I have a 26 year old Vaillant hot water boiler.
If I ever need to replace my boiler, will a mod con boiler work for me seeing that I have two zones? Being in Wisconsin, it appears that is my only choice after May of next year. Personally, I believe the payback on a high efficiency boiler would take too many years (at least in my case) to be economically feasible. Thanks.
Zones
Sure a modcon will work better than your old Valiant.
If you install the outdoor temp sensor it will even outdoor reset to save even more money.0
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 892 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
