Current draw for Taco 007-f5 circulator
BobF_2
Member Posts: 2
I have a two-zone-plus-hot-water hydronic system with Taco 007-F5 circulators on each zone (actually, the hot water tank circulator is an older model). About a year ago one zone went out (with the circulator occasionally making brief loud noises) -- I did nothing about it because that zone is where my wood stove is located, and I just burned more wood. Last week the other zone went out. I have purged both zones.
I checked the current draw of the circulators on both zones and each draws 1.2 amps. The rated current on them is .71 amps. Is this a sign that both are locked? I've seen a lot of conflicting advice on this. Most posts in this forum say that the current doesn't change that much when locked.
YUP
They are locked up. replace them.0 -
Might it not be wise to investigate why they both locked up? You do not want that happening to the new ones.0 -
could it be "locked" even if free-turning?
I took the cartridge out of one of the circulators and it turns freely and it and the chamber are perfectly clean.
Another question: the two branches of the supply line to the second floor zone each have the device shown in the picture inline. What is it?0 -
check valve
Looks like a heavy check valve to me.0
- 120 Geothermal
- 394 Solar
