Does anyone see issues with....
ctjomac
Member Posts: 52
I installed our new boiler in earlier posts and thanks to all who help me thru it.....ITS WONDERFUL! I recently installed a wood stove in our living room (a small one). The thermostat is located in this room and I was thinking of relocating the stat to another room further from the stove. I also wanted to shut both radiators off in the room with the stove. I have 388 sq. ft edr and a Burnham MST 396 working perfectly, but I don't want to shut these 2 rads. off if it will be an issue for the boiler. My wife loves the stove, but the heat still needs to go on as needed in the rest of the house. Thanks All......
I'd
go ahead and move the thermostat, and you might consider TRV's for the rads in the room with the stove. It beats opening and closing the valves. Just make sure you get the TRVs that have the integral vacuum breaker.0 -
Use TRVs
Hi- As Paul suggested TRVs should work well for you. You can't have
TRVs in the same room as the thermostat so the thermostat must be moved!
- Rod0
