Myster water?
jdnyc
Member Posts: 2
So we have an 8 year old Peerless boiler in a 3 story 3000 SF house, with the original piping, etc., from about 1915. The glass gauge indicated it was overfilled. I emptied and emptied, and of course the low water cut-off light goes on. Okay, gauge isn't woking... So genius I am I start putting water back in, with no way of knowing how much... Right, now too much, gets into system, burner starts, and the pressure cut off stops it. Water coming out of radiators, etc.
So local utilitly under contract comes out,. Fellow basically cleans out tube, drains boiler, and gets it going. He tells me I will probably need to take out some more water over the next day or so, as the water comes back down into the boiler.
Well here it is 5 days later, I am still taking 3 or 4 plastic pails a day out, just to get the water level to about 2" below top on tube.
The only conceivable source of water seems to be the water feeder valve is leaking, since we have low water cut-off but not an automatic feed.
So the question is (thanks for bearing with me)... Do I clearly have a leak in the feeder valve, whic is easy enough to replace, or do I just underestimate the amount of water in the system? In other words, I'm up to about 15 buckets in total so far after the guy left, I get the level down to proper level and the next morning I have to take out 4 or more buckets?
Any help is appreciated. I hate to calls these guys again, I'm in NJ by NYC, and a lot of people got hit by Sandy a lot worse than I did, and they definitely have better things to do.
- 120.1K All Categories
- 83.6K THE MAIN WALL
- 2.8K A-C, Heat Pumps & Refrigeration
- 52 Biomass
- 414 Carbon Monoxide Awareness
- 29 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.6K Gas Heating
- 114 Geothermal
- 151 Indoor-Air Quality
- 2.9K Oil Heating
- 49 Pipe Deterioration
- 735 Plumbing
- 5.2K Radiant Heating
- 355 Solar
- 13.8K Strictly Steam
- 3K Thermostats and Controls
- 50 Water Quality
- 36 Industry Classes
- 69 Job Opportunities
- 14 Recall Announcements
