r value question
BigErl
Member Posts: 29
I am attempting to do a heatloss calculation on a brick row house 15 feet wide by 37 feet long. There is a similar attached row house on both sides along the 37 foot wall. Since there is a heated home on either side what type of R value should I assign to these walls?
row houses
Are the two houses on either side heated? If so, you can usually disregard losses through those walls.0 -
Thanks SWEI. Yeah both houses have heat in them.0
- 117.5K All Categories
- 82.8K THE MAIN WALL
- 2.7K A-C, Heat Pumps & Refrigeration
- 43 Biomass
- 402 Carbon Monoxide Awareness
- 8 Chimneys & Flues
- 1.6K Domestic Hot Water
- 4.3K Gas Heating
- 107 Geothermal
- 148 Indoor-Air Quality
- 2.7K Oil Heating
- 45 Pipe Deterioration
- 679 Plumbing
- 4.8K Radiant Heating
- 353 Solar
- 13.3K Strictly Steam
- 2.9K Thermostats and Controls
- 48 Water Quality
- 31 Industry Classes
- 65 Job Opportunities
- 11 Recall Announcements
