Munchkin 140 has code PrO
Topper1
Member Posts: 2
How do I reset boiler so it has enough pressure to come back on? Or is this the problem? Could there be something else. unit is 8 years old.
Munchkin boiler
Hold on: Gas pressure or hydronic water flow pressure? Which error code specifically do you see?
Munchkins are okay with efficiency and general design, however their controls have a somewhat poor name in the Hydronic review community.
Cheers0 -
water pressure
PRO - is "low water pressure" - The water pressure switch is there to protect the boiler from low water/pressure conditions. Check to see what water pressure you have on the system. If it is below 12 # you need to find out what the problem is and correct it.
If your system is below 12#, the water pressure switch is just doing its job by alerting you to an issue.
If there is an issue with water pressure, could be failed expansion tank, failed pressure-reducing valve, etc.0
- 119 Geothermal
- 394 Solar
