Will unused (and undrained) main of steam system corrode if not repaired?
elfie
Member Posts: 264
have a section of a steam system where one of the mains is cold (likely due to a dysfunctional valve) and of course is not providing heat to rads (not really needed).
the condensate pipes and the main in this unused section likely has lingering water/condensate
would this stagnant lingering water lead to corrosion.leaks over time? and would it be best to drain if steam main problem is not be resolved
- 120.3K All Categories
- 83.6K THE MAIN WALL
- 2.8K A-C, Heat Pumps & Refrigeration
- 52 Biomass
- 414 Carbon Monoxide Awareness
- 30 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.6K Gas Heating
- 114 Geothermal
- 152 Indoor-Air Quality
- 2.9K Oil Heating
- 49 Pipe Deterioration
- 736 Plumbing
- 5.2K Radiant Heating
- 357 Solar
- 13.8K Strictly Steam
- 3K Thermostats and Controls
- 50 Water Quality
- 36 Industry Classes
- 70 Job Opportunities
- 14 Recall Announcements
