Baxi HT330 Parts
Scott M_3
Scott M_3 Member Posts: 32
Hi everyone, I had a Baxi HT330 installed in the fall of 2007 and with the exception of the expansion tank, all the parts are original. My service tech is going to clean out the combustion chamber and adjust the boiler as needed. He also suggest that I change the ignition electrode and the flame sensor. Since they dont stock the parts they have no problem with me supplying them when they do the work. I'm placing an order for these parts as well as the combustion chamber gasket and washer. I'm wondering if there are other parts that are prone to fail at this point that I should keep on hand (like a spark generator). Thanks for the help.
