Resetting Steam Pressure
BFlanzbaum
Member Posts: 25
I need a little education. Dan always says lower the pressure on a steam system.
Have a 2 story school with unit ventilators. They have installed a Heat Timer modulating control that modulates the gas valves. 2 boilers. I don't get it. If it is lowering the pressure form 5 to 2 or 3 i understand that they will burn less fuel but wont the supply air stay the same? Isn't 212 degrees 212 degrees?
If someone could give me a brief explanation that would be great
Thanks in advance for any input
Steam
Higher pressure = Higher temperature.
You will save fuel with modulation. The idea is that you start in high fire, then when all of the mains and pipes are hot, you step down, because you only need to then heat the radiators or unit heaters. The main pressure should be set just high enough to overcome the highest friction loss in the system, or to lift any condensate if needed.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
