sludge in skim port
rcrit
Member Posts: 74
I got a new boiler installed last year, a Slantfin Intrepid. I did a little bit of skimming but I know I didn't get it all (for some reason the wife objected to my having the heat off for hours).
I noticed one of my vents gurgling yesterday and found it full of water so figured it was time to do some more skimming. When I pulled the cap off my skim port I noticed quite a bit of sludge in the pipe. I scraped out as much as I could get and proceeded to skim for an hour or so. I'm going to try to keep this pace up for a while but with projected temps tonight in the 20's I'm not hopeful.
So anyway, I can understand sludge at my cleanout, but so high up in the boiler? Is this unexpected? Is there anything I should check?
crud in the skim port
You may be getting the stuff that was brought down by last seasons steaming. It may take a few sessions to get past the goop and onto just an oily film on the water.
I just had a boiler installed about a month ago and I've been doing a couple of hours worth of skimming about once a week for the last three weeks 2 or 3 gallons each time, I skim cold for the first gallon and then fire up the boiler to about 180 and just let it slowly trickle out. For the first two sessions I pulled out some nasty black goop in the first quart and then just water with some oil on it but this last skim on Monday was just the water with traces of oil. I know I've got to do it a few more times but the water in the sight glass looks fine - for now.
3PSI gauge0 -
I always get it there too.
It's the stuff that floats to the top when the water is boiling. It's the reason I pull my pressure relief valve and clean out the nipple every year. You might want to check yours next time we get a warm day.Just another DIYer | King of Prussia, PA
1983(?) Peerless G-561-W-S | 3" drop header, CG400-1090, VXT-240
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
