Is Peerless WBV03 enough to heat house and for 30 gallon Vaughn?
MCarpenter
MCarpenter Member Posts: 12
Hi, I am getting ready to install a Peerless WBV03 with a coil for a friend tomorrow however I am skeptical if in the future should we decide to throw a 30 gallon Vaughn, will the boiler not be enough to heat the house? There is 200 ft. of baseboard, small house, well insulated, We already have the boiler. just wondering if I should return it, to avoid any problems.
(another thought) if the water lines going to house from boiler are 1/2" the 30 gallon Vaughn tank in the future would be a waste of money considering the velocity of water going throughout house is enough with just the coil??
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,573
    Friend?
    If you were a real friend,you'd do a heat loss and a friend wouldn't let a friend have a single pass coil boiler with the high idle loss that goes with it!
