Who will fix a leaky radiator supply pipe?
EjG
Member Posts: 1
I've just turned my heat on for the first time this season, and found that a supply pipe to the radiator in my bathroom is leaking. It started 2 years ago, but last year the leak seemed to be in remission, so I did not pursue repair. When I first had it diagnosed, I contacted the company that installed a new boiler for me. They said they didn't repair radiators so I called a plumber. He also said he didn't do that kind of work. The pipe is very rusty and will likely have to be replaced. So, my simple question is, what type of repair person should I call if both a heating tech and a plumber turned down the job?
Thanks in advance for any advice!
try this
Click the find a contractor tab at the top of the page to see if someone is in your area. Out west it seems that boiler work is handled more so by HVAC guys but in the midwest and east, plumbers seem to handle it.0 -
Leak
I think the mentality of both contractors is ridiculous. A leak is a leak. Work is work. How can a company replace a boiler but not fix a leak? Crazy,
Hopefully, you find a good company through this website. Where are you located?0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 130 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 885 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
