flexible radint tubing
bobby12
bobby12 Member Posts: 2
looking for a flexible tubing oxygenbarrier for a radint system do not want to use the Watts Onix any ideas thank
  • kcopp
    kcopp Member Posts: 4,630
    Loads of choices....
    There are many Pex mfg... Uponor (wirsbo) is a great choice.
    hot_rod Member Posts: 26,604
    3/8 Uponor
    seems to be the most flexible pex I have installed. Warm it up in the sun or in front of a heater helps also.
    I have not tried any of the Pert tube, is it any more flexible?.
    If it is just a short section stainless corrugated solar tube is easy to shape. I would not do an entire radiant job with it.
    Rubber or EPDM hose could be isolated with a HX and non ferrous components.
  • Kent_3
    Kent_3 Member Posts: 60
    MrPex
    Check out mrpexsystems.com -- claimed to be the most flexible tubing
