I'd say 'wye'
Found this charming not-so-common fitting while sorting out some scrap to turn in - if I wanted another one (which I don't, just now....) what would I ask for?
I'd call it a 1 x 3/4 x 3/4 copper wye, but what do I know? I showed it to a nameless counterman, and he said 'they don't make those'. Hmmmm.
Just curious.
Vbob
    hot_rod Member Posts: 26,604
    search
    the fitting manufacturers websites, sometimes you can find unusual fittings like that. Perhaps they could supply one sample piece?
    hr
  • HDE
    HDE Member Posts: 225
    just different
    45° Wye C x C x C – Cast
    They are still made, but look different
    The one you posted you used to see in alot in baseboard systems, 1/2" basboard split runs with a common 3/4" return
    Some were even made with balancing butterflies in the branches.
