Update on Richardson
Fizz
Member Posts: 547
Latest on radsHad vaporstat installed, system running on 1-3 oz. Had 2 rads mentioned previously off as one valve was generic incorrect on Richardson rad, the other Richardson seized in closed position. While running system without these rads on it was perfect! Previously heard a clicking like sound when rads in question were open, last season, but hadn't heard since today, which is first heating cycle since I had a Mepco orificing valve placed on rads in question and they are open. Now the one rad doesn't get hot and the other gets hot just past valve union. Also, noted two other rads didn't get as much heat accross them. Is it possible one of els is blocked? If not where to look?
- 120.2K All Categories
- 83.6K THE MAIN WALL
- 2.8K A-C, Heat Pumps & Refrigeration
- 52 Biomass
- 414 Carbon Monoxide Awareness
- 29 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.6K Gas Heating
- 114 Geothermal
- 151 Indoor-Air Quality
- 2.9K Oil Heating
- 49 Pipe Deterioration
- 735 Plumbing
- 5.2K Radiant Heating
- 355 Solar
- 13.8K Strictly Steam
- 3K Thermostats and Controls
- 50 Water Quality
- 36 Industry Classes
- 69 Job Opportunities
- 14 Recall Announcements
