Beckett Genisys 7505
crash2009
Member Posts: 1,478
Need some help in the steam section. Thermostat is not shutting down the burner.
<a href="http://www.heatinghelp.com/forum-thread/142821/WM-SGO-3-short-cycling-even-when-t-stat-is-satisfied">http://www.heatinghelp.com/forum-thread/142821/WM-SGO-3-short-cycling-even-when-t-stat-is-satisfied</a>
SOLVED!
Bad t-stat wire. I ran new from first floor to my jumper split by my water feed valve but forgot to run from there to the boiler.0
