mix valve sizing question
slowflow
Member Posts: 1
trying to size a mix valve for 26 unit house.
stick with the 1-1/4" size or go bigger?
how is the watts n-170-m3?
recirculation pump necessary?
some units have 1 bedroom and some 2 bedrooms) but each unit contains 1 kitchen, and 1 bathroom (with faucet and shower).
pipes coming in and out of the tankless coil are 2".
cold water supply is 1-1/2"
return pipes are 1"
existing mix valve is 1-1/4" (old taco model # 587-1).
federal steam boiler, #2 oil, hot water comes from the tankless coil
need enough hot water for about 100 people (give or take, plus some have portable washing machines).
Thank You In Advance.
return pipes are 1"
- 128 Chimneys & Flues
