Hot water but no heat on radiators Beckett S100 Boiler 2 zone
OZOZ1
Member Posts: 3
in Oil Heating
Help!! I have a Beckett S100 Boiler which was
recently cleaned and serviced. I have hot water but no heat in the
baseboard heaters. I replaced the batteries on both thermostats but
still nothing. I hear a constant electrical hum from the triple Aquastat
relay and not sure if this is the problem or the relay attached to the
two zones since the pipes are only hot until that point. please help.
What could be wrong and how can I fix it.
Recently serviced
I would contact the outfit that serviced it. It may be something simple like a valve left closed, or switch left off.0 -
Tried That
Thanks, I checked all that, I even checked the two relay valves and nothing looks to be out of place. How can I test the Circulator pump and the triple aquastat relay?0 -
Power
Turn up your thermostat wait a few minutes check for power at the pump if you have power and no circulation bad pump. Make sure to wait because some zone valves take a few minutes to open.There was an error rendering this rich post.
- 125 Chimneys & Flues
- 19 Recall Announcements
