boiler vent
CMM
Member Posts: 2
can I install pvc sch 40 glued pipe on a Weill-McClain GV5 boiler.The existing pipe Plexco Plexvent is failing at the joints(silicons rtv 700)
No!
No PVC! AL29C is required. There was a recall on plexvent about 15 years ago,not sure if it still in effectTo learn more about this professional, click here to visit their ad in Find A Contractor.0 -
You need FlexVent
I have a GV6 and it was installed with the PlexVent. The next year, I got a call from the installer about a mandatory recall. They came out and pulled all of it and replaced it with a stainless steel FlexVent. There seems to have been a special FlexVent part supplied that could attach to the output flue elbow within the enclosure. I've been looking for this piece and I can't find it, so that I can replace a failed condensate drain.
I wonder if Weil McLain would still address the recall?
Later,
Johnbo0
- 86.7K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 69 Pipe Deterioration
- 951 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
