Grundfos Alpha question
Andy_27
Member Posts: 17
Hi,
I would like to replace a Taco 007 with an Alpha. In my current configuration the 007 is pumping into the boiler (it was that way when I bought the house). The Pump in mounted vertically pumping "down". When I looked at in installation instructions for the Alpha it gives three Horizontal configurations and one vertical. The vertical illustration is for pumping "up". SO - can an Alpha pump "down" ??
Yes
The motor assembly can be rotated so display isn't upside down. The IFC may have to be removed.0
