UV protection for PEX periodically exposed to indirect sunlight
HFC
Member Posts: 29
The Wirsbo 1/2” hePEX for my bathroom radiant floor
heat drops down from a soffit in the garage and connects to the manifold
mounted on a panel mounted to the wall directly under the soffit. The PEX from
the soffit to the manifold will be exposed to indirect sunlight when the garage
door is open. What type of sleeving is recommended to protect this section of
PEX from UV exposure?
some simple
pipe insulation would be fine.0
- 125 Chimneys & Flues
