Problem with domestic coil HB Smith model 8
Hi,
The fitting on my HB SMITH boiler is leaking at the domestic coil.  It looks as if the fitting coming out of the coil is leaking-- the heating co. that performed the maintenance said that the fitting cannot be replaced without replacing the whole coil.
Is this fitting a part of the coil?  If so, is there a less expensive way to repair this leak or do I need to replace the whole coil?  If I can repair the fitting, does anyone know a good place to get HB SMITH boiler parts?
Would it be a better option to simply cap off the domestic coil and install an electric water heater?
Your help is greatly appreciated.
Bill
  • Got pictures???
    Would help to see exactly where and how its leaking. May be repairable, may not.
    ME
