Burnham MPO vs System 2000
dkr
dkr Member Posts: 13
I have no idea what to do or which system is better. I have a 3 bedroom ranch in MA with a finished basement. I have forced hot water heat, 3 zones, (which we really only use 1zone 95% of the time) and a 40-50 year old boiler. Two estimates I like the best are the Burnham MPO 3 pass system or the Energy Kinetics System 2000. Both installers seemed experienced and competent. I am a complete idiot when they try to explain the benefits of each and I watched a video on the 2000 that I was given by the boiler guy. I just want to know which is the best system (savings, durability, etc.), any experience with either system that will help with my decision. Thanks
  • Bio
    Bio Member Posts: 278
    MPO vs Sys 2000
    Check this thread for System 2000 https://advice.thisoldhouse.com/showthread.php?t=11403 and do a Burnham MPO search on the wall, plus any recommendations the pro's may give you
  • Hydronics education
    Are in a rush to get the replacement in before the winter due to a leak or other boiler problem?
    If you have time, then buy a couple of hydronics books from the store here, and all of the choices will be easier to understand.
    I hope that the contractors did a heat survey of your house, before choosing the proposed boiler. It is not a good idea to replace the old boiler with one of the same size, before verifying the heat loss, as the old boiler may have been Ill-chosen.--NBC
    Steamhead Member Posts: 18,200
    Can't go wrong either way
    both the MPO and the System 2000 are first-class boilers.
    Consulting
  • Jim Hankinson
    Jim Hankinson Member Posts: 98
    Sys 2000
    Oversizing is not an issue with System 2000 since it purges the remaining heat at the end of a heat or hot water call to the last active zone.
  • Gordan
    Gordan Member Posts: 886
    I don't think so
    I don't think that all the issues associated with oversizing are simply resolved with a post-purge, and I would doubt that EK marketing or engineering would make such a claim, otherwise their product would not be available in such a range of outputs. In fact, their site states that proper sizing is key to efficient operation.
