Turning on a pump when any one of three zones is calling
Perk
Member Posts: 3
I've come upon a situation where there is an SR503 controlling 3 pumps and I need to turn on a forth pump whenever any one of the 3 zones is calling. Any thoughts on a device or approach that might make this a relatively painless and inexpensive fix?
Cheers,
Dave
Cheers,
Dave
Turn on another pump
Install a taco or any brand single zone relay and wire the tt from the sr503 to the tt on the new single zone control, and the tt dry contact from the single zone to the boiler tt0 -
to clarify ...
Thanks for your response. If I understand correctly, you are saying that by connecting the end switch (XX) dry contacts of the existing SR503 to the TT (RW) of the SR501, we will get the forth pump turn on when any of the 3 zones of the SR503 are calling. Lastly, connect the end switch (XX) dry contacts to the boiler where the end switch of the SR503 was previously connected to complete the loop.
Hopefully I have it right ... I'll let you know how it works out.
Best,
Dave0 -
wirng pump
Can't you just wire one pump to the boiler. It will reun on any demand on the boiler and continue to run while there is a demand.0 -
Used
The wrong zone control. Withthe SR-EXP version could have just wired in a system pump.
You can wire in SR-501 to the exisiting relay.
http://www.taco-hvac.com/uploads/FileLibrary/100-92.pdfThere was an error rendering this rich post.
work around
Thanks, Chris ... Good info for future installs. Right now I'm piecing together a work around on an existing system.0 -
Don't need
Any additional relays,wire 110v to one X terminal,other X to pump you want to control.To learn more about this professional, click here to visit their ad in Find A Contractor.0
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 892 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
