RTV?
Big-Al_2
Big-Al_2 Member Posts: 263
I'm finally going to fix my oversized short-cycling boiler.  I added three radiators already and am switching out my boiler.  I'm staying with the same brand and series, going from a Burnham IN-6 to an IN-5, so the steam piping changes will be minimal, basically a longer nipple on the return connection and a little shorter header.  I'm an engineer, generally pretty handy and it will be configured right.  I can use a pipe threader where I work, and the maintenance guys will help me set it up right.  I'd like to minimize any oil contamination to get away from a lot of extra skimming. I plan to wash out any new pipe before I install it.  Can I also stay away from oil-based pipe dope?  Can I use high temperature silicone  RTV gasket sealer as a pipe sealant? What would be the downside, other than it might not lubricate the threaads as well as conventional dope?   How about using teflon tape with or without a little RTV?
Suggestions?
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,511
    RTV
    I use the high temp caulk and blue Teflon tape on everything 2" and up. Lubricates very well. I am redoing my own steamer soon and if I have the guts I will try to hand tighten some of the joints. I haven't had any leaking joints using this method.
  • gerry gill
    gerry gill Member Posts: 3,083
    When i did my own boiler
    i did the 4'' pipe with just high temp permatex black gasket sealer applied to both the male and female threads and it worked incredibly well.
    gwgillplumbingandheating.com
