Pipe plug "fixes" leaking PRV
JUGHNE
Member Posts: 11,370
Call was for 80+ year old dripping CI radiator; only leaked during heating season.
No, we can't take it apart to fix nor easily buy a new one. Go for a look at the boiler and of course the pressure gauge is shot, sitting stuck on 40 PSI. Look to open the PRV and find a 1/2" pipe plug in the bottom drain opening!! It is a 3 year old B&G combo fast fill & PRV. So the eventually the storey comes out; 3 years ago something dripping/leaking in bsmt--local HVAC guy looks at it & orders new--helper comes to install later--all is good--lady calls him back 30 minutes later--something still leaking--helper fixes leak with 1/2" ips plug and all is good again. 3 years later radiator leaking. Jump to yesterday: remove plug, drain 1 gal water, pressure drops to 16 PSI ,gauge was actually good, fire boiler: pressure up to 25 psi in 30 seconds--of course compression tank completely waterlogged. HO says that gauge pegs out over 80 psi in the winter time. I think their Angels are with them all the time and gave the warning at the leaking kitchen radiator.
Boiler is Bryant 8W-26 C LG (now NG) SN 21177 180,000 BTUH. Surprised by Install book being inside cabinet "effective 7-1-54".
100 year old house, gravity piping, all CI radiation, had pump added with this boiler. Of course could just do a cleaning, get air in the tank, flush out boiler, (probably never done in 60 years) and leave out the pipe plug!!
HO show interest in higher efficiency, I don't believe condensing unit justified for this CI system. The only item I'm uncomfortable with is the Gas Train----Basco valve with t-couple pilot--Bryant Diaphragm main gas valve (1/2 A634 SN:9KT) -- adjustable water temp control limit control (not electric) "Titan T-43-B" which has 1/4" Al tubing to act on the diaphragm of main valve. It does light off nicely though.
Any suggestions--total replace--clean w/new gas train. Thanks! JUGNE
- 86.8K THE MAIN WALL
- 56 Biomass
- 105 Chimneys & Flues
- 5.6K Gas Heating
- 104 Geothermal
- 69 Pipe Deterioration
- 952 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
