Riello oil burner won't fire
Johnnyx
Member Posts: 3
in Oil Heating
Hi, I replaced the nozzle and oil filter for my Riello oil burner about six months ago, recently the burner suddenly stopped firing . I had to to turn off the circuit breaker off and then turned it back on again in order for it to restart. I have to reset the circuit breaker about once a week for about a month now. Could you tell me what causes this to happen?
Thank you. I'll appreciated.
I have no idea. Could be lots of reasons. That sounds like a problem that needs a professionals eye.0 -
capacitor?
I just changed the oil filter and nozzle, but still with no luck. Could it be a capacitor problem?0 -
Johnny I'd Like to Buy A Vowel
Could we have some better hints? The motor runs, but burner doesn't light, or the motor doesn't run.
Anybody got those winning lottery numbers for tonight?0 -
The motor doesn't run
After it ran for few days, then the burner locked out. Even I pressed the reset button, it won't fire, motor is not running. So I have to turn off the circuit breaker, wait about 5 minutes, then turned the circuit breaker on. Then the motor started to run and the burner fired up right away. The first time I reset the circuit breaker, the burner worked for more than a week before it locked out. But now, it worked for less than a week before another locked out. Do you think it's the capacitor problem?0 -
This isn't a guessing game
I could spend half the day listing things that could possibly be wrong, but without the knowledge of the system, it's not gonna do you any good. Call a pro0
- 125 Chimneys & Flues
- 19 Recall Announcements
