can't read the boiler plate
Duff
Member Posts: 61
OK who's got a little trick to share. Went to look at a boiler tonight and I wasn't able to read the specification plate on the boiler.The boiler is a 6 section converted steam to hot water oil fired. The monster has 1-2" supply tapping and two 1-1/2 return tapping's. The burner is a not a flame retention just a gun type. Can I put something on that plate to bring up the lettering and stamping?
Thanks in advance, Dennis
Sure it's not gravity hot-water?
take some pics and post them here. One of us might recognize it.All Steamed Up, Inc.
Consulting0 -
Pencil tracings?
I've taken a clean piece of paper and placed it over the label, then used a pencil, with light pressure and made a tracing of the plate. May take more than 1 try but does show you whatever impressions are on the plate. Will need to be as clean as it can be before you attempt to recover the impressions.
METhere was an error rendering this rich post.
Useless information
Other than curiosity,what value is the plate info?To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
thanks for the help
Mark, I'll give that a try, thanks
Mr O'Brien..This house just had an extension put off the side and a full dormer on the second floor. I believe the boiler in place was over sized for the original house. I'm in the middle of doing a heat loss for the entire house for the proper size boiler that will be needed. If the boiler in place can handle the load I may suggest to leave it in place for one more season and just pipe in the additional zones. The plate would help in this situation.0 -
Minor correction...
Pencil RUBBING, not tracing. Google pencil rubbing for mor details.
- 86K THE MAIN WALL
- 52 Biomass
- 421 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 96 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 892 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
