Replacing a old Crane
fixitguy
fixitguy Member Posts: 99
After 15 years in the HPAC business, My first 2 pipe steam job and what a beauty. A 1948 Crane 198,000btu. Set up very nicely. I almost wish that I could replace the cracked section, but its time to say goodby. The customer has chosen a Peerless 63, a good choice for this application, I have installed quite a few of them in steam and hot water. The house has 250 sq ft of radiation and the customer wants to add another 100 to an addition. My quandry is what to use, a 03 or a 04L my instinct says the 04L, but will I be oversizing it to much?
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,506
    edited July 2012
    radiation
    Make sure that the steam mains can handle the extra radiation. A 2" main should handle 350 edr with no problem.
    Steamhead Member Posts: 18,191
    Go with the 63-04L
    that way there won't be any issues when the addition is built.
    What kind of 2-pipe system is it?
    Consulting
  • fixitguy
    replacing a old crane
    Its a Richardson, nice and simple, and beautifly built
  • fixitguy
    adding another takeoff to a 3" drop header with 2, 2 1/2 risers shouldn't be a problem.
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    edited July 2012
    Boiler size
    Is there a hi-lo burner for that boiler to accommodate the range of edr from present to future needs? Maybe Peerless has a "mod-u-pac" available.--NBC
  • fixitguy
    hi-lo burner
    Great idea, not that I know of at the present time.
