Use of Baseboard without diverter
H01945
Member Posts: 3
I am doing major rehab of 60s era house that has a single baseboard loop around the entire lower level (slab). I am doing one room and would like to install 2 3ft radiator baseboards in place of the total perimeter to gain wall space. I can just continue the single loop, or can I use braches-- as you would with tees-- to gain some temperature control in the room. If I use parallel branch with a three way ball valve, would that work? Any thoughts?
First things First
Based on the "heat loss" that you did for the room, what is required to heat it?0 -
Am using two high output baseboards at 6 feet (Multi/Pak 80), which was obtained by online calculator from SlantFin. The present loop includes 10 feet of finned baseboard.0 -
Check
the posting" hydronic circulators and TRV's", good info.0 -
thanks
Good info in that discussion. I will try to find a reasonable 3way diverter valve for 3/4 pipe to include next to the radiator.
Thanks0
- 120 Geothermal
- 394 Solar
