burnham in4. header?
jonny88
Member Posts: 1,139
Hi.I am installing an in4.I am piping 2 two in risers out of boiler.do I have to reduce the equalizer and loop or is it ok to keep everything 2inch.thanks in advance.
Two things
Two things, why would you use both tappings? Are you just going the extra mile? If so, good for you! Also, it's certainly ok to keep everything 2 inch, in fact, its preferred (if I'm understanding you right).0 -
extra mile
Im going the extra mile but I just want to make sure I'm not doing it in vain.thanks for your help
Ø0 -
Not at all
Not at all, using both tappings can only help in the production of dry steam. However, you'll want to be carefully how you connect them, but this is all available in the Burnham Literature. As for the Hartford loop, you'll probably want to connect that in whatever size it is now, usually 1-1/4. So you would use an 2 x 2 x 1-1/4 steam tee for example.0 -
loop
The old loop was 1 inch copper ten inches above water line.0 -
So make it
So make it a 2 x 2 x 1 steam tee and drop the center line of the Hartford loop to 26 5/8 above the finished floor.0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 975 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
