Goodman motor Question
DaveW
Member Posts: 1
Hello, Does anyone know if I can replace a 1/3 H.P. motor with a 1/2 H.P. motor in a Goodman 14" Cabinet? One guy said I could, but I would have to swap out the cage and blower housing, which is fine as long as it will all fit.
I know the 1/2 HP motor is used in the 17 1/2" cabinet currently. Thanks
Not a motor question!
You have a lot of converting to do. Yea,maybe, possibly, go for it ! Or not!
What, no takers? I think you can replace just the motor and run cap,if RPM/rotation are the same. There is a little thing about "oversizing " motors and it's called electricity. That electricity inside the motor will produce a different,excessive, amount of heat due to some crazy mathmatical "formula" due to oversizing,and "slippage" and it is called "Inverse Porportionality". Oversizing by one size only is generaly allowable but not two sizes. Look at those "miracle motors" ,those "multi H.P. motors", a given "tap" is only good for 2 different H.P.'s then the next "tap" is good for two more H.P.'s. Hook up the 1/2 h.p.tap to what was a 1/4h.p. load and you can kiss that motor goodby.0
- 120 Geothermal
- 169 Indoor-Air Quality
