Brand new AC compressor burns up three days after new replacement was installed
jcobb3
Member Posts: 1
Brand new AC compressor burns up three days after new replacement was installed.
What could of caused this?
Here is the whole story sorry it's so long.
I have a exactly 5 yr old hvac unit in my home. the heat
pump/ fan motor under the house and a 2 ton(i think) ac unit outside. it uses
the 410a Freon in it. One night I came home and my house wasn't as cool as it
should have been. Checked the breaker and found that it was flipped so i
flipped it back on and 2-3 seconds it flipped back off. went to inspect the a/c
unit and the 3 prong plug was not connected and was black on both male and
female sides. Service tech came said the compressor was bad, but luckily under
warranty so just had to pay the shipping. He replaced it Thursday June 28 and
on Sunday night July 1 when I got home, same scenario all over again, flipped
breaker, 2-3 seconds it flipped back off. Only this time not only was the 3-prong
plug out, but Freon started spraying everywhere out in the yard. Tech said
lightning must of hit or something. Just now replaced the compressor again, but
said it needed to have acid away ran thru it first before he could charge it up
because it was acid that caused it.... So what do I really need to do cause it kind
of feels like I'm getting the run around?
WOW!
What 3 prong plug?Volts,amps of plug? Exactly where did the freon escape from the system?0 -
check plug
I am wondering if your tech checked the molded plug for a short within itself.
On a side note: I have seen the area between the compressor spade connectors blow apart and refrigerant leak out there after a lightning strike.0 -
Now that's a dang shame. The old compressor failed and a new compressor was installed.........? Hummm? I am sure the work order the tech. provided you with stated:,.. what happened, why it happened, complete details as to corrective measures and the final operational details as to the equipment operation after repair... So his company has it in thair files. Or,.. that's what I'd do if my name was on it. So what does his work order say? Just curious.
As an addition, someone stated that, or asked if the tech checked the "plug"? He had better have check EVERYTHING.........no excuses.:-) I think we are talking about the compressor terminal block???
Peace
Mike T.0 -
3 days
Oh!That PLUG!They don't become loose very easily,and you happen to have two in a row! Interesting! What is the status w/ the 3rd comp? How many (of us) Tech's have used that AcidAway stuff? I never have. jcobb3,after the 1st comp was replaced, did you have cooling from the AC for 3 days and then it failed? And the 2nd? The AC worked good for those 3 days?? The freon came out of the comp terminal block/plug?0
- 125 Chimneys & Flues
- 19 Recall Announcements
