unico txv
polcat1p
Member Posts: 28
im 99% sure this is the 410txv valve, but maybe someone on here could verify. i have the mc2430hx. the unit was hooked up to a heatpump, by the original owner. I want to hook up to a 410 goodman ac only condenser. numbers dont o the txv valve dont jive with my unico paperwork. the numbers letters on the vavle are
45 zga
bp/15
4405
would this be ok to hook up to ac condenser only?
thanks
45 zga
bp/15
4405
thanks
TXV
The numbers you gave are the Sporlan # of the txv,not the Unico part #. If the AC only cond unit matches up to the BTU of the old H.P. then no problem.0 -
unico
t have the old condenser paper work, but its for 2 models
american standard
4a6h2018-060a1000aa
4a6h4018-060a1000aa
maybe they had a 1-1/2 ton hooked up to the unico?
i guess i could reserch sporlan.
thanks0
- 125 Chimneys & Flues
- 19 Recall Announcements
