Liners for steam pipe
Tree59
Member Posts: 4
Are there any pipe re-lining systems for steam/condensate systems?
I am working on a project at a prison campus
Steam is distributed to all buildings
The pipe is quite old and failing
I was hoping someone knew of a product, and had some experience, with a reline system suitable for steam
jac
jac
Steam Pipe Liners
Hi Jac- Welcome to "The Wall". You might want to post your question on the Main Wall as this time of the year more of the pros hang out there. The Steam section is really busy in winter but in summer, rather slow.
- Rod0 -
Tree59
My first post........Thanks for the advice0 -
holey pipes in the big house
is the system in operation now? what sort of leaks are there:P [pipes, fittings, traps]? i would be worried that any sort of relining system might interfere with the condensate drainge, causing water-hammer. what range of pressures are in the system?
generally, steam and condensate pipes in a well-maintained system are remarkably rust-free, as all the oxygen has been driven out of the water.
are you an engineer?--nbc0 -
Prison Steam
Yes the system is in operation
We are in the proposal stage and have not done field investigation
The system pressure is 100 psi
Engineer - yes0
- 125 Chimneys & Flues
- 120 Geothermal
- 169 Indoor-Air Quality
