Radiant Heating
Steve_210
Steve_210 Member Posts: 664
Hi,
My supplier is telling me that you no longer need to use Pex Aluminum Pex with Warmboard, that some type of regular Pex is approved.  Has anyone had any experience with this? Please advise,
Thank you
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,686
    Their new Web site
    has a good installation video and they say PEX/AL/PEX only in that program.
    Have you called them?
    Retired and loving it.
  • bb_5
    bb_5 Member Posts: 15
    Warmboard Approved tubing list
    Can be found here:
    http://www.warmboard.com/sites/default/files/pdfs/ApprovedTubingList_0812.pdf
    Not just PEX-AL-PEX anymore.  Please read the list or contact Warmboard directly  @ 877-338-5493
  • DanHolohan
    You might want to edit that video.
    Could be causing some confusion. Thanks.
  • NRT_Rob
    NRT_Rob Member Posts: 1,013
    regular pex is often allowed
    as per that list but I don't know anyone who has done PAP and PEX who would choose to do PEX... it doesn't stay nearly as well.
    Rob Brown
    Designer for Rockport Mechanical
    in beautiful Rockport Maine.
  • bigjohn
    bigjohn Member Posts: 2
    installer owner
    I am doing radiant in-floor heating in kitchen with solar thermal per-heat with 50 gal nat. gas water heater back up. I am using Roth panels 3/8 pex tubing . hard wood over this
    has been hard to find that would warranty it. So I am thinking of Hardy-backer broad with
    Paramount 18x18 tile tile.Should I also use underlayment (Schluter Ditra) then lay the tile? Thanks  Big John
  • bigjohn
    installer owner
