Paging ME
SWC
Member Posts: 7
Hi Mark,
I was speaking with my 75 years young retired engineer friend on Saturday and he informed me that he had turned his water heater down to 120 F for the summer.
I suggested this was a very bad idea because of the risk of Legionairres Disease.
His dear wife has an autoimmune disease and other health complications and has had several bouts of pnemonia in the last few years.
I told him to immediately turn the temp up to 140+ and leave it there.
He feels he is protected because he is on a municipal water supply.
Do you have any links or suggested reading I could pass along to him?
Stephen C
Stephen C
Absolutely...
Thank you for watching out for your elderly friend, and doing the right thing as it pertains to the education of the public as it pertains to this deadly disease.
http://contractormag.com/columns/eatherton/cm_column_645
http://contractormag.com/columns/eatherton/cm_column_656
http://contractormag.com/columns/eatherton/cm_column_668
http://contractormag.com/columns/eatherton/cm_column_681
http://contractormag.com/plumbing/cm_column_98
There are a LOT of web sites available on Legionella Pneumophila. If you google those words, you will get a lot of hits.
HTH
ME0 -
Thank you
oops..0 -
Thank you
That list will get him started down a safer path I hope.
The Europeans mandate a daily temperature boost or something don't they?
And, he is definitely not elderly ! That's ageism. ;-)
Thanks again
Stephen C0 -
Not sure if it is mandatory or voluntary...
But I can tell you that the Euro's are light years ahead of North America as it pertains to recognizing and addressing the issues.
http://osha.europa.eu/en/publications/literature_reviews/legionella-policy-overview.pdf
I do know that all of the German boilers I've seen have that sanitization feature as a part of their controls.
And some N.A. boilers (Lochinvar) have an adjustable set back program that could be programmed as a sanitization feature. I keep all of my water heaters above the 130 mark just as a precaution.
ME0
- 114 Geothermal
