Hot Water Control
lenster
Member Posts: 3
I am a newbie trying to sort out an answer for my hot water
and how it is controlled.
1) I recently had my oil service providers technician tell me that
the thermostat on my Bradford White "water heater" needed to be
replaced and that it is easy to do as it is not covered by their service
contract. I agree but with some caveats. The Bradford White was installed
apx 8 years ago. Hot water is generated by my boiler (E.F.M.) ( the boiler was
my hot water source prior to Bradford White installation) and delivered to the
Bradford White (aquastat? indirect?) The bradford white delivers to
wherever it is needed, shower, dishwasher, faucets, etc. ? I have never been
able to regulate the temperature on the Bradford White. Water temp has
always been way too hot.
2) The thermostat on the Bradford White ( Apcom WH9 thermostat) has never
seemed to have worked. I cannot get the water temp down below a scald
level. There are currently NO wires going to the single heating element.
This suggests to me the Bradford White is merely a holding tank and water temp
is controlled by my boiler. Is this the case? All wiring diagrams
show wires attached to the heating element on the Bradford but dont know if it
should be that way in my case. I called Bradford White and they said that
they couldn't help me. Call a service tech.
3) This suggests that the hot water is generated and controlled by the
thermostat on my boiler, a Honeywell, with a High limit and a Lo limit with a
differential to be set between them. Does the thermostat on the Bradford
call for the boiler to reheat which seems quite often throughout the
day? Every hour or so. Does the Bradford send cooled off water to the
boiler and its sensor then go off to reheat?
3) Should I just replace the thermostat ( I have a new TOD 59T to replace the
Apcom WH9) on the Bradford and just see what happens? How would this
thermostat control water temp to my service areas. All explanations and
help with this are greatly appreciated. Does that thermostat on Bradford
control the outgoing water temps? Then how does it know to get reheated or more
hot water? Confused on this process. Thanks, Len
MIxing valve
You have to install mixing valve to temper water to for the domestic hot water usage. adjust it to 115-120F at faucet. set heater to 140F, to prevent legionella .Gennady Tsakh
Absolute Mechanical Co. Inc.0 -
Water Heater Controls:
Please post photos of the water heater, the boiler and related piping from the boiler to the water heater.
Is there a circulator on the water heater tank?
I do installs for this all the time and I never have this kind of problem. I think it is piped improperly. The only thermostat that might need to be replaced is the bottom one that runs a circulator. And if you turn it up and down, it should "click" at the temperature inside the tank. It is only a switch to run the circulator.
The boiler temperature should be set no higher than 150 degrees on the "operating" side with the high limit, 20 degrees higher. If the lower thermostat on the water heater is set to 120 degrees, the water in the top of the tank might be a little higher for a while but it should settle out.
Need more information on your system.0
- 120 Geothermal
- 394 Solar
