taking a zone of a steam boiler?
jonny88
Member Posts: 1,139
hi.is it possible for me to take a zone from a steam boiler and feed a cheating coil for forced air in the loft of a house.one person told me to use a heat exchanger with a pump on both sides while another told me to take the boiler water through a storage tank with coil and then pump up to heating coil.heating coil is about 25ft above boiler.thanks
Heat Exchanger
You would get the best heat transfer using a flat plate heat exchanger.The zone has to have a means of filling, backflow prevention,expansion, air removal, etc.0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 971 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
