Replicating Richardson System elbow return
Fizz
Fizz Member Posts: 547
Could a machine shop replicate Richardson System(see older systems this site) trapless elbow return which includes ball cock and dip tube?
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,884
    Anything is possible
    If you got the do-re-mi. :-)
    The hard part would be reproducing those castings, or welding up something reasonably close from standard pipe sections. It would help if technical drawing were available. The pictures in the PDF leave quite a bit to the imagination, so it could take a few iterations to get something that actually worked.
  • Paul Fredricks_3
    Paul Fredricks_3 Member Posts: 1,556
    17C
    I just used a Hoffman 17C radiator trap. Seemed to work fine.
