TSP and commissioning
Solid_Fuel_Man
I've read on here about some using TSP for their commissioning fill up.  I know this makes a very basic solution depending on concentration.  Would this flush out bits of oil from the machining, pipe threading, and flux from the copper?  Is this left in a system, run hot then flushed, or left in indefinitely? Never heard of doing this until I read it on here, the boiler cleaners available at Sid Harvey seem to be a soap base and not really get this sludgie oil out of a new system as evidenced by removing y-strainers after a year or so of operation.  Seems like a system with a flat plate exchanger would suffer the most form a slight sludge buildup.
Thank you for all your help!
Taylor
  • Alan R. Mercurio_3
    Alan R. Mercurio_3 Member Posts: 1,624
    Chemicals
    Taylor, I’m pretty sure there are very specific instructions on the use of this product. I don’t have it locked into the old memory bank (sorry) and I’m not at work so I can’t run out to the warehouse and grab a bottle to read from. I’ll gladly do that Monday if it helps?
    Also I think it’s worth mentioning that you should always check with the manufacture before introducing chemicals of any type to the system. You may find some chemicals are not approved and/or recommended for use in certain boilers.
  • Jean-David Beyer
    Jean-David Beyer Member Posts: 2,666
    That is for sure. My boiler manufacturer specifically warns not to use TSP in my boiler at any time, even if you flush it out immediately afterwards. I am sure they fear the cast aluminum heat exchanger would not be improved by the TSP.
