Heating Alert! - Taco
DanHolohan
DanHolohan Member, Moderator, Administrator Posts: 16,706
<a href="http://www.heatinghelp.com/article/203/Taco/2397/Taco-s-New-0015-3-Speed-Pump-Line-ready-for-Heavy-Duty">http://www.heatinghelp.com/article/203/Taco/2397/Taco-s-New-0015-3-Speed-Pump-Line-ready-for-Heavy-Duty</a>
Retired and loving it.
  • CMadatMe
    CMadatMe Member Posts: 3,086
    00R
    Its my understanding that this new pump is just a 00R with a new name. I thought it might have been their anwser to the Grundfos UPS26-99 but was told its just the current 00R.
  • Joe Mattiello
    Joe Mattiello Member Posts: 751
    00R, and the new 0015
    Hi Chris
    The new 0015 is not the same as the 00R.  The 0015 is an all-new family platform using single speed, 3-speed and variable speed motor options for a wide range of Hydronic, Radiant and Solar Thermal applications.  It also includes a new Stainless Steel casing option for use on Domestic Hot Water recirculation (DHWR) and other open fresh water applications.  Both casing materials come in standard in-line or rotated flange options and include an Integral Flow Check (IFC) as standard.
    The Cast Iron 0015 3-Speed is a direct replacement for the current 00R 3-Speed and the Grundfos UPS15-58FC, B&G NRF-25 and Wilo Star S21F etc.   A Stainless Steel 0015 3-Speed version is a direct replacement for the Grundfos UPS 15-35SF and UPS15-55SF for DHWR and opens fresh water systems.
    With the addition of Taco’s Variable Speed control options, the 0015 can be adapted to many other applications including 0015-VDT for maintaining a constant system Delta T, 0015-VR (Outdoor Reset) or 0015-VS (Set Point) for Radiant injection mixing or 0015-VT for Solar Thermal systems.
    The existing 00R-3-Speed s will be discontinued, effective June 2012 and replaced by the more universal 0015 for a wider range of models, options and system applications.
    Joe Mattiello
    Taco Comfort Solutions
    Steamhead Member Posts: 18,442
    But does it have great curves?
    Can't find the curve chart for this circ, Joe- can you dig it up for us?
    Consulting
  • Joe Mattiello
    0015 curve
         attached is the information you requested
    Joe Mattiello
    for the quick response!
    Consulting
  • CMadatMe
    Joe
    Its the same curve as the 00R. What is the benefit of using this pump over the existing 00R? I was hoping this pump was in addition to the 00R to match the Grundfos 26-99 3-speed.
  • Joe Mattiello
    0015 attributes
    Chris, I have explained the attributes of the 0015,  when comparing it to the soon to be obsolete 00R.
    The 0015 includes a new Stainless Steel casing option; both casing materials come in standard in-line or rotated flange with an Integral Flow Check (IFC) as standard.  As you mentioned the Cast Iron 0015 3-Speed is a direct replacement for the current 00R 3-Speed and the Grundfos UPS15-58FC, B&G NRF-25 and Wilo Star S21F etc., but it is not equivalent to the Grundfos 26-99.
    The now available Stainless Steel 0015 3-Speed version is a direct replacement for the Grundfos UPS 15-35SF and UPS15-55SF. Another, cool feature  available for the 0015 is the variable Speed control options, including the 0015-VDT , delta T,  0015-VR outdoor Reset, 0015-VS set point, or the 0015-VT solar thermal pump.
    So when you say they are the same pump, you mean the performance characteristics only; right?  Obviously, the 0015 has many more available features to handle most of your application needs, which is why the 00R pump is going away.
    Joe Mattiello
